Hi,
I intend to buy an internal WiFi card for my PC
Please fast forward to the message #7
///////// old message
and in my country I have the following options available:
Rosewill RNX-N250PCe, 300Mbps, PCIe --> 30e
vs
Linksys WMP600N --> 60e
The money is not a problem, but I would not want to buy something that I really do not need. From what I understand the Linksys model has 'double-band', that if I understood correctly can give you advantages if you're planning to use smartphones, tablets... something I will not use.
My only concern is which one of the two will give me better signal/less lag .
Any advice? Read that many N250 were DOA on newegg.
Cheers
vs
Cheers
