Wireless card stops working after overclock!
Boltaction
My linksys WMP54G v4 can't find my network after I overclock my processor.
AMD Thorton 2000+ 133fsb to
2600+ 166fsb
Im using DDR333 Ram too.
My PCI/AGP bus is the same though (33) before and after ocing. What should I do?
whats the point of testing in another computer? The card functions fine when it is not overclocked. I could try another PCI slot, but that doesn't sound like the culprit. IRQ's are not being shared. I will try it and update you in 5 min.
Sounds like you need a board with a lockable PCI/AGP bus like the NF7-S. I had a similar problem trying to overclock a Barton on an MSI KT3 Ultra.
Overclocking with multipliers works wonders. But i see u don't have a mobile 2600 so urs is locked i think! =/
yes its locked to heck. Funny thing is my PCI bus is the same speed, overclocked or not.
