I'm trying to study to take some of the MCSE tests so I've setup two old computers, one with Windows XP Server 2k3 and the other with Windows Xp Pro.
The problem is I can't get the XP Pro machine to see the Server 2k3 machine.
I'm not positive, but I think the problem is that I am using a Linksys router for connecting the machines together. They are both able to get to the internet and ping to the router, but neither machine can ping to each other.
Currently my cable modem is connected to the Linksys router and then the machines are connected to the router. I have tried setting the Server 2k3 to static IP and have tried switching the router to being a gateway, but nothing has worked.
Is it necessary for me to get a small 4 port hub to connect them? Or is there something I am doing wrong that they should be able to connect to one another currently?
