Right. You'd have to get replacement hardware from the manufacturer anyway. You'd also have to use one of their installation discs or recovery partitions. This information isn't very scary. It doesn't appear to affect OEM builds, although the wording isn't clear.
you cant. i found this out a couple of weeks ago with an hp preloaded with win8. i wanted to install a clean copy of win8 and have my own key but no go. i dont know if you could load win7 on it i didnt try but win8 during setup said the key was invalid for this setup would even let me enter one.
The bigger issue though is how UEFI and Secure Boot work in general -- and it means you can't move hard drives between identical systems without having the fecal matter hit the fan.
The only way Microsoft is ever going to solve this is by making windows 8 public domain , if you look at their OS there is no hope in HELL that they will ever solve piracy
From the people who brought us Internet Exploder, give me a break.
Why not get off the band wagon and actually try IE 9 sometime.....
Windows Server
Exchange
SharePoint
Honestly, I've never used a product key from a pre-built system on another computer. I didn't even consider it, which is weird since I don't exactly have a problem with software piracy.
It's a good thing no one makes games besides Valve.
It also means that I can swap a hard drive from one failed Dell machine to another identical Dell machine without having to jump through hoops and reactivation. With Windows 8 and the UEFI Secure Boot crap, this is no longer possible. Basically, this just makes the life of an IT support person even more of a headache.
Certainly true, but if you had to, you'd really rather play games on a console than play them on a Windows 8 PC?Most mainstream games are available on consoles while crowd funded indie games are making their games available on Linux and Mac too. Lots of alternatives out there.
What this also means is that, per Windows version (Home, Pro, etc), every Dell system out there actually comes from the factory with the EXACT same Windows key installed. The one on the side of the machine is never used unless you do a full reinstall from non-Dell media.
BIOS-based Windows 8 product keys? So what happens when you have to reinstall Windows 8 after your motherboard dies? What about installing your legit copy of Windows 8 from an older system to a new build?
Windows Server
Exchange
SharePoint
Say thanks to the software pirates out there, who forced MS to remove the "one manufacturer = one key" option.
How do people robbing ships on the high seas have anything to do with this? And why would someone rob a ship to steal boxed copies of Windows.
