- Aug 20, 2006
My first thought: Same old shit. I am going to attempt a clean install now.
For the people that are having issues with installing Nvidia drivers what cards are you running? Are they pre Maxwell?
What exactly about W10 can't you tolerate. W8 was a more refined W7 ( sans metro ) and W10 is a more refined W8. The W7 people are starting to sound like the 60 year olds that live out in the sticks refusing to let go of 98SE/XP.
I run dual monitors on GTX 980. Had 8.1 Pro + nvidia drivers installed prior to upgrade. Upgraded to 10, then installed latest nvidia drivers. Zero issues.
- Microsoft Edge has problems transitioning when you want to drag a tab to a new window, it spawns a new window in a default spot instead of where you dragged it.l
- BIG FUCKING MINUS Can't disable updates, can only "defer" them for a couple months, the old system was better to me because I was able to review each update manually and decide accordingly
the forced updates aspect really is stupid and they need to change that pronto…
Overall, no problems on the upgrade (Windows 10 Enterprise Edition). Everything seems to work fine. I still am not a fan of the ads popping up, or the stuff on the search bar. I hid it, but I'd rather disable that garbage. At least I can access my start menu now without a third party plugin.
My system does boot slower though with Windows 10. Also, I'm not quite a fan of Edge yet. I'll give it some time.
sucks that I have to ditch my sound card for onboard audio if I want to use Windows 10 as my sound card manufacturer went out of business (Auzentech) and there are no driver updates
anyone figure out how to pin the recycle bin, my computer, or folders to the live tiles thing?
Mind if I ask if you were using Windows 7, 8, or 8.1 Enterprise to begin with for the upgrade? Was this some MSDN/TechNet edition or from a legitimate business/commercial thing? And have you checked to verify that yes the Windows 10 Enterprise upgrade is now activated properly?
I'm not 100% certain but I don't think that's possible.
You should be able to right click and select "Pin to start". It works on any folder, library, hard drive, etc. Here's my start menu with all my folder shortcuts set up:
Microsoft edge browser.
I read someone say it is incompatible with many websites. WTF is the good of a browser that only works on some sites?
Did it take 5 hours or more for anyone else to install it, I downloaded the iso a while ago.
I know this may sound stupid but, It's there any way to change the Clock format to 12hours instead of 24hours?...
In the other hand, so far impressed really to how fast and smooth went the installation process, but also impressed how well are running certain games actually versus windows 7, definitively the resource management its really improved specially in the CPU side.
