(cf)Eclipse
Freelance Overclocker
- Feb 18, 2003
awesome viper.
and lithium, it's not the memory (controller?) being pushed too far?
(cf)Eclipse said:awesome viper.
Viper87227 said:I've had 5 winnys, im bound to get atleast one 2.8ghz capable chip.
(cf)Eclipse said:well i still need the week to put you in the database![]()
(cf)Eclipse said:i'm not sure actaully. i think i might have seen an LBBID before..
revenant, can we have the full first and second lines of the opn?
wow! that's something new. is there any copper around the edge of the heatspreader? or is it roughly lapped just to remove the label?Viper87227 said:well, this is the most bizarre thing. I took out that 3200+ today, eager to see its stepping. Well, what do I find? THe heatspreader is totally blank. It appears as tho emachines had lapped it. I will still try my hand and OCing it, but that this point its useless to your chart, since there is no indication of what the hell it even is.
I bet they wanted to hide that its a CBBID![]()
dmonkey said:Did increasing NF4 Chipset voltage help much with stability?
Viper87227 said:No, with A64s, the chipset plays much less of a roll in OCing. In AXPs, the memory controller was on the chipset, so increasing voltage as well as better cooling helping overclocking... but now that the memory controller is on the CPU, so the chipset doesnt play as big a roll in OCing.
pigz said:quick questions;
how does the 3500 winni oc compare to the 3500 clawhammer oc? on water? how do i know if mine is a clawhammer or newcastle? cpuz says newcastle, i thought it was a clawhammer
lithium726 said:is taht second voltage option int eh bios (i cant remember what its called) raise voltage going to the mem controller? i might try for 1T if thats teh case...
wrong. CPU-Z reports claws with half the cache as newcastles. they are rumored to be FX rejects, and clock quote highViper87227 said:If cpuz says its a newcastle, its a newcastle. as far as OCing goes, I believe a newcastle will usually OC better
whats the "CPU VID"? it goes to 1.55vNo. There is no option to raise your memory controllers voltage. The voltage options you get are cpu, memory, LDT (HT), and chipset.
