I've tried running for awhile with x4 HDD's and x1 SDD in my system:
x1 128GB C300 Crucial SSD
x2 1T WD Blacks
x2 2T WD Blacks
(mobo: Asus Sabertooth P67 rev1)
With all those drives in I couldn't take the sluggish feel of the system. Mostly I'd notice it when I opened a drive. It felt like Win7 was doing something like waking all drives in the entire system when accessing a drive - like sometimes a full minute or more of a wait before the drive opened and was usable. I don't really notice it with two of the 4 HDD removed.
I've been thinking about getting an external enclosure - just started trying to read up on them. As far as I know - my mobo is suppose to support eSata port multiplication. Anyone have any tips on exactly what to look for in an external enclosure? Mostly I just want something next to the system than I can turn on and off easily via a power switch to have available only when needed.
I think I'm leaning toward this ProBox:
http://www.amazon.com/ProBox-Drive-...1?s=electronics&ie=UTF8&qid=1331563869&sr=1-1
Also looking at:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817198047
It doesn't look like the Icy Dock has a front on/off switch and it's $65 more than the IcyBox. But it does have a built in PSU instead of needing a power brick. The ProBox having a side connecting power cable seems very odd. Any thoughts on what I should be looking for here?
Also - I've seen some people say that WD Green drives are good enough to stream 1080p video while others have said it's not fast enough. If I was to stick x4 WD 2TB green drives in a box, would the speed in RAID make up for the slowness of the green drives? I really don't care about RAID otherwise, if I can stream 1080p well, that's all the HDD speed I need. Those 'green' 2TB drives are so much cheaper than the WD drives it's hard to pass up.
Thanks
x2 1T WD Blacks
x2 2T WD Blacks
Also looking at:
Thanks
