Win2000 Pro Keyboard Error
murph
This may be quite a boring topic, but I'm stuck...so here goes:
OS = Win2000 Pro
Problem: It will let you log into the LAN but once the OS comes up completely, keyboard just craps out except function keys and Windows key. The odd thing is, that I can't type anything for example in notepad, but if I hit Ctrl-A, it works fine, but apparently the letter keys don't work by themselves.
Attempted fixes:
New keyboard --> Nothing
Update drivers --> Nothing
Beating keyboard senseless --> Nothing (except a headache from the noise)
Does anyone have any ideas what else to check ? Its not a huge issue at the moment, but a little assistance would be great.
Thank you,
Murph
Update: If it helps, it will boot into safe mode into DOS...any new ideas ?
Have you tried switching from a PS/2 keyboard to a USB one, or vice-versa?
No, good point. Now I need to track one down. I only have a few floating around company somewhere.
Thanks, I'll give it a shot.
I think as long as you can get hold of a PS/2->USB adaptor, you should be set.
Maybe the keyboard PS/2 port on the mobo is shot.
