I have Win 7 64bit installed... hardware listed in signature below.
Everything was working fine post-install, going through driver installs and I have this HUGE issue :\.
The default nvidia graphics driver (WDDM 1.1) that comes with Win 7 properly recognizes my monitor's resolution (1920x1200) however, installing either of the last two WHQL certified nVidia drivers (not using Windows Update, using the .exe from nVidia's website) makes my computer have the dumbs and not be able to recognize my monitor's resolutions. It was only letting me use the 800x600 or whatever it defaults too.
Not to mention, I think on the second to last driver IIRC, it worked, but the screen was OMGCARWASH - all my text was blurry and the screen looked washed out, it looks like I was running VGA or something (but it was over DVI!). Apparently this is an issue in Vista from Googling... that still hasn't been solved in Win7.
Anyone encounter this before? Looks like I have to maybe do some INF/EDID hacking later on... I'll also try just using Windows Update as well to see if that works.
I can't believe how drivers and monitors nowadays still have these issues. MONITOR: HI, I HAVE THESE RESOLUTIONS AT THESE FREQUENCES. GPU: OH HAY, OK, I'LL REMEMBER THAT!
In the real world... MONITOR: I FORGOT MY EDID. GPU: LOL WHO ARE YOU?
