Just wondering if anyone is seeing this problem. I have two USB thumb drives that are locking up Windows 7 (64bit) when you select "eject" and then remove them. It does NOT crash BSOD the OS, but it does freeze everything. All I can do is they ctrl>alt>delete and then restart which works. But the cursor is totally locked up when this happens.
So far, I have only tried two USB thumb drives and they both work just fine on my XP laptop. They also read/write just fine in Windows 7, it is ONLY when you do the "eject" and remove it they lock the OS.
I can't think of anything that would or should be causing this and was just wondering if anyone else may have this issue or seen a report? It seemed OK at first, but now it seems like this happens almost every time. Any thoughts?
Thanks.
Thanks.
