Win 10 Laptop Hard drive always at 100%
Discussion in 'General Hardware' started by craigdt, Jul 7, 2018.
  1. craigdt
    craigdt Gawd
    683
    Oct 27, 2016
    This is my brother-in-law's laptop for school.
    Intel i5-8250U
    8GB RAM
    1TB spinner disk
    CPU very low- 0-10%
    Memory steady at about 4GB
    But the HDD is always at 100%, with nothing running, making it really slow.
    Virtually brand new.
    Scrubbed of all Dell factory bloatware performed
    Nothing special in startup programs
    Very clean- normally a machine like this runs just fine.
    Ive disabled Windows search, doesnt help.
    Disabled Windows MSE.
    Performed all Windows updates, restarted multiple times.
    Malwarebytes, SuperAntiSpyware and Spybot scans
    Rolled back Adobe Flash updates
    Set to high performance mode
    Disabled the superfetch service
    Set virtual memory to1.5gb min, 12gb max
    What other things can I do, besides flatten it and install a (long overdue) SSD?
  2. pendragon1
    pendragon1 [H]ardForum Junkie
    10,087
    Oct 7, 2000
    open task manager and sort by drive usage see whats hitting the hdd. there has to be something running causing it. remove mb, sas and sb as they have background tasks.
    criccio likes this.
  3. criccio
    criccio Fully Equipped
    11,108
    Mar 26, 2008
    Even better, once you open task manager, go to the performance tab, click open resource monitor at the bottom, open the Disk tab, then organize the Disk Activity section by Total (B/sec) and see which actual file(s) are being accessed.
  4. Tiberian
    Tiberian DILLIGAFuck
    5,361
    Feb 12, 2012
    Could be something defective going on with the drive itself, use Resource Monitor to see what's actually using the storage media, what processes, then go from there. On a clean installation of Windows 10 you can expect to see some extra disk activity for at least a day or two as it indexes the contents of the drive(s) but that shouldn't last more than a day or two. If something is causing constant use of the storage Resource Monitor should be able to show precisely what's doing it.
    Was typing this post even as criccio posted effectively the same thing above. :D
  5. m_isom
    m_isom Limp Gawd
    347
    Oct 27, 2006
    Leave the laptop on for a while, check for all the available windows updates. I have seen this a lot recently and all of them have been doing background updates and eventually go back to normal use.
    pendragon1 likes this.
  6. Brian_B
    Brian_B [H]ard|Gawd
    1,408
    Mar 23, 2012
    My guess is the HDD is about to go tits up, and your seeing are re-reads from error correction
  7. craigdt
    craigdt Gawd
    683
    Oct 27, 2016
    Thanks for all the input.
    The #1 thing is "System" at 3,061,000 B/sec
    Anything after that is negligible.
    Absolutely nothing.
    Top thing is "system" at 0.1MB/s
    Looks like April Windows 10 Update 1803 is stuck on 80% "Preparing To Install" .
    Wasnt doing that before....
    So now Im working with the Windows Update Troubleshooter, and its been stuck at "Starting the Bits service" for like an hour.
    Ugh. Ima bout to just say screw this and start over with a LTSB installation.
  8. pendragon1
    10,087
    Oct 7, 2000
    if theres nothing on it run the recovery and do a clean install, should be an option.
  9. craigdt
    craigdt Gawd
    683
    Oct 27, 2016
    Update-
    Looks like the April update 1803 has been stuck or trying to prepare/install for the better part of 2 months, bringing the whole machine to its knees.
    Really my first experience with some of the issues other folks hate about Windows 10....
    Used the Update Troubleshooter tool to unfuck it.
    Can you imagine a non-computer person trying to deal with this?
    They'd take it to the clowns at OfficeMax or just buy a new machine because they think they don't have enough memory or something.
    Atrocious.
  10. Mega6
    Mega6 Gawd
    686
    Aug 13, 2017
    upgraded my dual boot linux laptop twice today to latest fedora. was it perfect? no - there was a repository I had to disable so the first upgrade would proceed. nothing is perfect as it was created by humans. i expect things not to work.
    criccio and craigdt like this.
