Historically, there's never been a .2 version of ESX(i). Just sayin...
Not that I know for sure or work for or know anyone that knows for sure. But I'd put a large sum of money that it's version 6. I need to get through the VCAP-DCA..
you are right, I do believe we will see a huge public cloud push this year though. Even more than before
Bottom line is that anyone that knows can't say. But going by the session info and blog posts on VMware's site you can expect an announcement. If I were you I'd go ahead and update the VCP with that course.
^^This. We'd all get lit on fire if we said anything.
Another question along the same lines. Does anyone know if 5.1 is covered on the vSphere 5 VCP test? Looking at the exam blueprint I don't see anything about SSO, etc.
I'm assuming the 5 test is still current? I need to go take my test (took the class over a year ago now, never got around to taking the test). I'm still good with vSphere 5 class -> VCP 5 test?
Yes, you'll be AOK.
Hell, they still offer the VCP4 test don't they?
Huh..didn't mean to put NFS in there. I'll fix that. Thanks! I like the storage policies... But needs more management visibility.
vSphere 5.5 embargo lifted. Three new posts on my blog. www.jasonnash.com
Solid wrap-up... Hated knowing SSO was being fixed yet being forced to to 15 5.1 upgrades last month. The RSA iteration is almost as embarrassing as vRAM.... well, slight exaggeration.
I haven't been able to get a solid answer this week, but will the flash read cache capabilities be available on PCI cards (i.e. Fusion ioDrives)? I would like to put ioTurbine use to rest.
Not yet - driver limitations of the emulation layer (I'll double check to make sure - they emulate a block device instead of a SCSI device) - that'll be fixed soon from what I've heard.
I had heard that once, then heard otherwise so I've been trying to get a good answer.
Duncan has a post up saying that it does work with PCIe?
http://www.yellow-bricks.com/2013/08/26/introduction-to-vsphere-flash-read-cache-aka-vflash/
The ssd read cache looks interesting to me, my small biz clients typically have just a few vm's and local storage behind a raid controller, so somewhat limited performance.
Can the SSD be over provisioned, or does it automatically use the entire disk?
Does this cause a shit storm during an HA event if the server you're restarting on doesn't have enough cache to accommodate it? What about DRS conflicts?
Some good reading so far! Anyone want to snag a copy of the pocket gudie from Pernix Data?
I'm not able to make it to VMWorld.
I can probably grab you one.![]()
So, nothing new regarding NFS? Still NFS v3? Really would like to utilize multiple 1Gb interfaces better rather than spending the cash on 10Gbe upgrade
Additional vSphere 5.5 Storage Feature Enhancements
VAAI UNMAP Improvements
vSphere 5.5 introduces a new and simpler VAAI UNMAP/Reclaim command:
# esxcli storage vmfs unmap
As before, this command creates temporary files and uses UNMAP primitive to inform the array that these
blocks in this temporary file can be reclaimed. This enables a correlation between what the array reports as free
space on a thin-provisioned datastore and what vSphere reports as free space. Previously, there was a mismatch
between the host and the storage regarding the reporting of free space on thin-provisioned datastores.
There are two major enhancements in vSphere 5.5: the ability to specify the reclaim size in blocks rather than as
a percentage value; dead space can now be reclaimed in increments rather than all at once.
Tried today but struck out as they weren't handing them out till 4 and that's when one of Duncan's sessions started so I opted not to hang back. Hopefully there are more available tomorrow.
