Will this work fine?
M0R4
Hey there! I decided to make changes with my PC and take some new parts, so I'm still wondering if this combination will work fine: (I'll use it only for gaming) http://www.amazon.co.uk/gp/product/...&pf_rd_t=101&pf_rd_p=418448347&pf_rd_i=468294 with processor http://www.amazon.co.uk/AMD-FX6300-...F8&qid=1378540134&sr=1-1&keywords=amd+fx+6300 this motherboard http://nikem-bg.net/computer-components/GB-970A-UD3---AMD970--AM3- and also I would be glad, if you could give me good enough powering for this parts, beacuse my current one is way weak.
Thanks!
All those parts should work out fine, and come out to be a pretty good system.
I would recommend upgrading the power supply to a good, quality, (Corsair, PC Power & Cooling, Seasonic, Antec, etc.) 550-650w power supply.
Please answer the stickied "ANSWER THESE QUESTIONS FIRST!" so that we can help you better.
