Ok, so I have picked out my final selections for my system. I just need to know will the entire system fit together properly, esp, is there enough room in my case for this setup?
Case: Thermaltake Armor VA8000BWS ATX/BTX Full Tower Case
PSU: PCP&P TURBO-COOL® 850 SSI
CPU: AMD Athlon 64 FX-60 Dual-Core
Motherboard: Asus A8N32SLIDeluxe Socket 939
Video Cards: BFG Tech 512mb 7800gtx x 2
Sound Card: Audigy 2
DVD Drives: Liteon SOHW DVD/RWs x 2
Hard Drives: WD 36GB Raptor & WD 72GB Raptor
Ram: Corsair TWINX2048-3500LLPRO
CPU Waterblock: Little River Waterblock Storm G5 1/2 or 3/8 OD
GPU Waterblocks: The Danger Den SLI Solution using two NV-78's 1/2 or 3/8 OD:
Radiator: ThermoChill HE120.3 1/2 or 3/8 OD
Resevoir: Typhoon Single 5.25" Bay Reservoir CLEAR 1/2 or 3/8
Pump: Hydor SELTZ L 40 II Water Pump - 1/2" or 3/8" Conversion (740 GPH)
Fans: Panaflo 120x38mm Ultra High Speed Fan (FBA12G12U) x 3
I don't know wether to go with 1/2" OD or 3/8" OD. Which should I pick?
