Will this ram overclock decently?
Foz2001
I'm kinda on a budget and cant afford the best ram but still want to overclock the amd64 3000+ im getting.
My first choice was
CORSAIR VALUE SELECT DUAL CHANNEL 1024MB KIT PC3200 DDR CAS2.5 2X512MB
but i'm guessing that it wont overclock much at all..... what about this ram?
CORSAIR TWINX1024-3200 PC3200 2X512MB DDR CAS2 SILVER HEAT SPREADER
that would be my limit in $ to spend on ram, I plan on overclocking around 3500+ speeds, but dont want to take a hit on performance of the ram. What do you guys suggest?
The Value Select has two strikes against it for an A64 system - it's high latency and because it's Value Select, it's not rated for high MHz. A64 likes low latency. The TwinX is definitely the way to go.
Rule of thumb - never cheap out on your memory stick. Always get the lowest latency / highest cycles you can afford. If you cheap out, you'll regret it later.
TAKE IT FROM ME.
I bought the VS ram thinking it would be a nice cheap RAM to oc and well i just closed a deal for some mushkin "222" ram to OC and am now selling my corsair. yeah, go with the latter RAM.
QFT
I ended up getting new memory after I initially bought Kingston ValueRAM....and it sits in my closet right now waiting to be sold or used.
