Vertigo Acid said:Yep, compared to Ultra, the Modstreams are great. I'd still prefer an Antec Neo, however
Heh, what about a window case like mine where the PSU isn't visable behind the metal coveringjonnyGURU said:Actually... I use the Ultra, thank you very much.
ALL modulars are going to have the same issue: Voltage drop due to the resistance created by the connectors. But this resistance is minimal. Like .6 milli-Ohms versus .65. Take a look at this thread: http://hardforum.com/showthread.php?t=895505
As for the Antec... eh... I'm still not gungo ho on dual 12V rails, yet. And the Neo is so freaking ugly, the only advantage to the modular design is the air flow improvement. Wouldn't put it in a window case. At least the Modstream looks somewhat cool (that is.. If you're into bling.)
IF you decide to get a Powerstream over a Modstream because you don't "need" modular cables, don't go with the 520ADJ. The 420ADJ gives you just as much usable power.
Vertigo Acid said:Anyways, why in god's name would you willingly submit your components to an Ultra PSU?!
They're like chinese fireworks: Build cheap and end with a bang!
Honestly, I hope you're joking
Personal experience is *not* god when it comes to reliability. I'm sure there are people out there that happily drive their pintos and yugos to work everyday and have never had a problem, just as I have a topless Deer that runs a dual P3 server on occasion. Just because I haven't set it on fire doesn't mean that it is built well. As for RMAs, RMAs != Failure Rate, especially when you only have a 1 year warrenty, and quite possibly the people who buy these supplies aren't going to push them like some of us do.jonnyGURU said:I'm not joking. And you're basing your comments on personal experience?
All of this has been said before, but I guess I have to say it again... sigh.. I have two of the X-Connects and one X-Finity, oldest one coming up on a year and have had absolutely no issues. Furthermore, the last two VAR's I've worked for has sold the product and have had no higher RMA rate on their product than other brands we've sold (about 2%.)
And that's all I want to discuss on the matter. I knew before signing up for the second time here that [H]ard|OCP is an Ultra bash-fest. Something I feel is unsubstantiated, but also something I don't care to get involved in (guess it's too late for that, eh?)
Vertigo Acid said:See http://silentpcreview.com/article193-page2.html
All i'm saying is that I'd rather have a PSU built like a tank or close to it *protecting* my investment. Maybe it's not a big deal to you that your PSU puts out more noise and has a nice .5v overvolt on the +12v rail by default. But that's not good enough for me.
Irishllama said:Why Did you sign up for the second time,eh? Just wondering.
Vertigo Acid said:But indeed you've just proven my point; a PSU should be able to regulate all voltage lines independently of eachother, regardless of the load presented, as long as there is some load.
As you note about SilentPC Review's findings being "circumstantial at best", I would respond that so are you personal experiences.
Not trying to attack you directly at all; just sick and tired of people recommending PSUs based not on hard facts and accurate numbers, but anecdotal evidence and hearsay. If the Ultra line of PSUs can not keep within spec during foreseeable load conditions, then it should not be recommended!
BTW, the links you provided were great. One thing that I immediatly thought when I read that was, what about times when you've got other components drawing +5v power, but your CPU is idle, and/or your GPU is idle? Wouldn't that present as a possible scenerio when +5v draw would outpace +12v draw?
