I'm putting together something for my brother... not sure how well this will do with crysis though:
Budget is $500.
CPU and Mobo combo from frys:
AMD Phenom Tri-Core Processor 8450 & ECS A770 Motherboard
(http://www.frys-electronics-ads.com...-Tri-Core-Processor-8450-ECS-A770-Motherboard)
HDD:
HITACHI Deskstar P7K500 HDP725032GLA360 (0A35411) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive
Video Card
PNY VCG96512GXPB GeForce 9600 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
Case + PSU
Rosewill R218-P-BK Black 0.5mm SECC Steel ATX Mid Tower Computer Case
Rosewill RP500-2 ATX12V v2.01 500W Power Supply
RAM:
A-DATA 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model ADQVE1B16K
Optical Drive(s):
LITE-ON 20X DVD±R DVD Burner Black SATA Model iHAS120-04 - OEM
Total is going to be $518 with tax and shipping.
Now I'm considering this other video card:
EVGA 384-P3-N851-AR GeForce 8800 GS 384MB 192-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130332
And it seems like the one I have is pretty much better in every way except for the stream processors... ???
(This is the card I was looking to get: http://www.newegg.com/Product/Product.aspx?Item=N82E16814133216)
Thanks
Budget is $500.
HDD:
Video Card
Case + PSU
RAM:
Optical Drive(s):
Thanks
