So I'm thinking I'm going to go ahead and dive into a WC setup, I'd like to have as few parts as possible with decent performance because I intend to overclock my i7 920 D0, I could probably do it just as well on air cooling but I'm an enthusiast so I'd like to go all out, here are the specs of my computer:
Case: Silverstone TJ09 - (I already have the radiator brackets to mount it so my choices are slim for dual 120mm rads)
MOBO: Gigabyte GA-EX58-UD4P
CPU: Intel Core i7 920 D0 stepping
RAM: GSkill 6gb
GPU: EVGA 9800GTX+
HDDs: Dual Intel X-25M SSDs w/ RocketRaid 2302 Raid 0
PSU: Seasonic 700W PSU
Inside the case I have the two Silverstone 120mm fans that came with it, plus 2 x Noctua 120mm fans (they will be mounted to the rad) and another Noctua 120mm fan cooling the harddrives.
So here's what I've been looking at for a setup, keep in mind I'd like to keep it as compact as possible because I had having stuff all over in the case.
Koolance Pump&Reservoir - It fits into a 5.25" bay
Link: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=367&products_id=25341
Swiftech Radiator MCR220
Link: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=200&products_id=3653
HEATKILLER® CPU Rev3.0 1366 LT CPU Water Block
Link: http://www.performance-pcs.com/cata...=product_info&cPath=498_495&products_id=25217
PrimoFlex Pro LRT Black Tubing -1/2in. ID X 3/4in. OD
Link: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=292&products_id=23924
Primochill Resuable Hose Clamp [19mm, 3/4" OD] - Black
Link: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=298&products_id=24888
Feser One F1 Cooling Fluid - Clear/UV Blue - 1 Liter
Link: http://www.performance-pcs.com/cata...=product_info&cPath=381_383&products_id=22686
All of this stuff will have 1/2 barbs and obviously 1/2 ID tubing, the reason I went with the Primochill tubing is because I wanted black tubing, but I didn't want UV Black.
My Silverstone TJ09 is the black version with a window, my goal is to have a black and white contrast, with black tubing, white lighting and maybe a couple of white LED fans, not quite sure, I haven't figured the whole thing out yet.
I went with the Koolance system for a couple of reason, one being that it's compact and is basically an all in one solution for the parts that usually take up the most room, and I'd like to have a minimum of clutter. I went with that Heatkiller block because in benchmarks it's only a couple of degree C from the top-dog Heatkiller CPU block.
I am also thinking about adding in watercooling for my GFX card what else would I need for that? Could I mount a single 120mm radiator in the loop to help with cooling? I read somewhere that a decent dual 120mm radiator with proper cooling is good for 300W - 600W of heat dissipation and a single 120mm was good for about half that, whether or not that's true, that's what I'm here to ask you guys!
One more thing, I was looking at this upgraded version of the Koolance Res&Pump:
http://www.performance-pcs.com/cata...e=product_info&cPath=59_367&products_id=21424
Should I be getting that one? I didn't think it'd be necessary considering that I'm going to have a pretty small loop that's not very complicated.
Any help from all of you would be greatly appreciated! I'd like to get this right the first time!
RAM: GSkill 6gb
GPU: EVGA 9800GTX+
