Will My Mobo Work With This Case
ok well as of right now, i have an hp pavilion a1213w desktop computer. ive been all about customs, but this deal came along and i could pass it up. buy anyway
it has a micro atx motherboard, model number. asus K8S-LA(salmon)
heres an image K8S-LA Motherboard
ok well with this current case i have, it has the power button wires, and hard drive led wires setup as 1 black connector. it has all the correct colors in order.
im looking to buy this case Pc Case
and it uses separate connectors for power, hdd led, etc.
and was wondering if theres anyway i can use my motherboard with that case.
also heres an image of my mobo, with the power input selected
Motherboard Picture
anyone who can help it would be greatly apreciated, i dont just want to spend $70 and not be able to use it, and have to go through the hassle.
and if this thread should go somewhere else, plese mods move it. im new here
It looks like a pretty standard mATX setup. You shouldn't have problems in that case. I used that case in a build for a friend of mine and IIRC, it took mATX boards. All the screws might not line up properly, but there looks like there is enough of them that you can mount it.
