Will I need to mod my case?
fsh42na
I've got a Coolermaster Wave Master. This will house my first A64 system:
DFI Lanparty NF3 250gb
A64 3400+
2x512 mb Crucial Ballistix PC3200
BFG 6800 GT OC video card with Artic Cooler 5 aftermarket cooling
Maxtor 120gb; Seagate 200gb
Liteon 52x CDRW
NEC 3500A dvd burner
Enermax 550 watt power supply
The case came with a solid left side panel. I also ordered a windowed side panel.
I installed the optional top blow hole fan. It came with 2 front intakes and 1 rear exhaust. These are all 80 mm fans.
Do you think I'll need to mod my case by either cutting a hole on the left side panel?
Thanks for your responses :confused:
