VanGoghComplex
- Apr 5, 2016
I've got a PWM fan header on my mobo which I want to use to control a 2-wire watercooling pump. The pump is 6w, so I know the header will have the juice for it.
I found a little chiclet made by Phobya that will turn a PWM signal into a corresponding voltage level, so you can control 3-wire fans from a PWM header.
Thing is, my pump has no tach wire. I don't know if the PWM output will function without some kind of speed feedback.
Anyone else done anything comparable and have some insight?
