will a pinmod change my default voltage?
Ciggarilo Himself
In my bios I cant change the default voltage of 1.525v and I want higher voltage for overclocking,by performing a "Pin mod" will the default voltage change in my bios?
Will my bios recognize the voltag increase?
Or will the voltage stay the same in my bios but be actualy running at the new voltage because of the "pin mod"?
What you might want to try is just getting a used 865/875 board from the FS/FT section of the forum. You can probably get one for $30 or so. With the right board, you'd be able to adjust voltage and possibly fix your IDE controller issues :cool: .
