Will a mobo boot with no CPU?
Status
Not open for further replies.
[IO]ERROR
On the way to work this morning the woman called me to tell me the computer wont work. I had her reboot(aka unplug it) it and nothing. She said the monitor was on and the computer power light was on but no beeps or anything.
I just put this rig together last weekend so I'm guessing I might have gotten some bum parts.I can test the video card and PSU in my old rig but it's a AMD 929 system and the new system is a C2D. Since this is my 1st C2D rig I don't have any way to test anything. I know I can pull the ram and post to bios but my question is can I post to bios without the CPU?
When I shut off the monitor last night everything was ok and running fine. I went to bed and the woman found is dead this morning so I'm pretty sure I didn't cook anything unless the fans died in the middle of the night. Also the room was ice cold from the A/C running.
System Specs
Mobo: P5B Deluxe (NEW)
CPU: C2D e6400 (NEW)
Ram: OCZ / 2GB DDR2 PC2-8500 / 1066MHz / NVIDIA® SLI™-Ready Edition (NEW)
Video eVGA 8800 GTS SOC (Had this)
PSU: Hiper 580 PSU (Had this)
no...no CPU and the board won't boot period.
Yeah I didn't think so. Now the question is without another C2D mobo or CPU how can I figure out what the problem is.. :(
I just got them both from Newegg.com so I might just RMA them both back if I can't figure out which is bad.
No CPU, No Post.
However, you can pull all the parts except the cpu,mb. Reconnect both PS connections, clear the bios and see if you post. If not, swap the PS. If you don't have an extra, use a PS voltage checker, or volt meter to see if you PS is working correct.
Something is bad somewhere. I doubt it's the CPU unless you had that thing overclocked to the 9's.
No CPU, No Post.
The only OCing I did was bump the FSB to 400 mainly cause I'm using the stock HSF till I finish building my case.
I have another PSU to swap in so when I get home I'll pull both ram chips and see if it will post then the PSU. If I can't get a post there I guess I'll take the CPU to a shop since everyone I know runs an AMD rig :( and have them test it out.
While testing my OCing my CPU temps never went above 74deg and that was running at full load for a while. Lastnight my rig was idle all night. I'm hoping the woman is nuts and the cat knocked the monitor cable off the back or something dumb like that. :rolleyes:
You should be able to use any LGA775 CPU, you don't necessarily need a Core 2.
Umm, sorry I have to ask, but what the heck are you doing building systems for other people if you don't know how to troubleshoot? :rolleyes:
play nice people :D
anyway.. In my experience it takes alot ..ALOT to kill a CPU, most likely you killed your board. Ive seen CPUs killed more by improper mounting ( crushing it with heatsink, or Arctic Silver on the pins)
you'll fry your board way easier than frying your PC Idalmost say thats a fact.
Status
