Will a cheap mobo work for me??
-iLLuZioN-B18C1
if im just planning on doing basic things with NO overclocking and run things like msft office, browse web email ect..., and just run regular programs can i get the cheap mobos like ecs?
i dont understand exactly why you need a goob mobo. is it to overclock only?
Pretty much. That and extra features like gigabit ethernet, SATA-II ports, etc.
It's best to look at reviews of a particular board before buying, though.
ok...so it sounds like the mobos dont actually help performance, but moreorless that the features that come with it?
the budget mb's come with just a few extras and don't have as many overclocking features .
but i have built a few ECS a754's and a939. they have all been good mb's and even alow for overclocking up to 250fsb and they have been exceptionally stable. the quality is much better than the price would indicate . i picked up a a754 nf4 from ewiz for $47 on sale a few weeks back. it in actual use compares well to the more expensive mb's .
If it's your only machine, I would say get a "Brand" motherboard. On the other hand, I picked up an ECS 848P-A7 today with a P4 841 to run Folding@Home and it's running like a champ tonight ! No installation problems , but I'm only running a console linux installation with networking, no sound, no graphics.
A64 mobos don't affect performance that much since the memory controller is on-die. With the P4, the mobo controls the interaction between the memory controller and the CPU, so the mobo manufacturer has more control. Either way the difference isn't that great. If you're not OCing, a cheap board will work for you.
should be good, but if you plan on upgrading in the future the mobo is the thing to spend your cash on now
