Will a 600w psu be enough for this rig?
would a tuniq potency 650w psu
http://www.newegg.com/Product/Product.aspx?Item=N82E16817611007
be enough to run a gtx460 1gb sli rig with a AMD Phenom x4 965 3.4ghz cpu and 4gb of memory?
Specs wise, yes but without only 95W leftover which means no overclocking.
But I would not get that PSU at all. There's no proper review of that platform showing that it can actually provide its rated wattage/amperage. There's no UL number to help determine who actually built the PSU. So in other words, the lack of key information about the PSU and its actual capabilities makes that PSU a bad buy for a gaming SLI setup.
The PSU is made by Sirtec, and probably uses a design similar to the OCZ ModXStream Pro line. Not great, but it should be enough for your system.
