Wich Motherboard
wallie32
I am going to build an Athlon 64 computer and would like advice on which motherboard to use.
I am not a gamer my main interests are Adobe Photoshop and Adobe Premiere.
I do no want SLI but would like SATA2, plenty memory slots, Firewire.
Two boards I have been looking at are the Asus A8N-E and the Epox EP-9NPA+Ultra.
Any advice by anyone using these two boards or general advice on the best board would be very welcome.
Thanks
wallie
If you're OCing, look at the Epox. If you're running stock, look at the Asus. Either one is a good board. You can't go wrong.
i use the asus a8n-e board and it is a great board.it o/clocks well doing sane clocks,its rock solid.never crashes.im running a 3200 venice @ 2500mhz all on stock voltages.cant say any thing bad about the asus.
ive heard the epox is also a good board.i didnt care for the power connector placement and generally the layout of the asus is perfect in my opinion.i thought about the epox but i read some of the user reviews at newegg and it just seemed there were alot of doa boards and it made me think.its kinda like the guy before me said you cant really go wrong with either board.
I'm in the same boat. I've read a few reviews, and it seems that both are good.
I don't plan on getting another video card anytime, so SLI is not necessary.
I would like to keep the options open with overclocking though, as I'll have a 3700+ san diego and a good heatsink.
I'm also seeing positive feedback on the ECS KN1 Extreme board, as well as the ABIT AN8-ULTRA
Price variance is about $15 between the 4 boards, and I just want a rock solid board.
any other opinions?
I've had issues trying to OC my current Abit AN7 motherboard with the 2600+ barton mobile athlonxp, so I'm not as pleased with Abit as I am with other brands I've had.
I've had great OC's very stable on: Gigabyte & Shuttle boards though. I stuck an old nforce Epox board in my mother's computer and it's been running solid for about 5 years now.
if you want sata2 you usually have to get an sli board, as sata2 is only stock on the nf4 sli boards. if you dont mind doing a simple pencil mod under the chipset fan, you can enable sata2 and sli on nf4 ultra boards. since just about all nf4 boards are pretty much the same, choose by feature set, accessories and bios options. will you overclock? will you use raid 5? will you use more than 4 sata drives? do you care what color your board is? do you need 4 or 5 fan headers on the mainboard? do you need more than 3.2v for your ram? do you need more than 1.55v for vcore? built in wifi? 8 channel sound? on board sound blaster live? hd sound? 1394? all these options will cost you. the epox is a good, stable board, plenty of voltage but not extreme, stable, 3 pci slots, fairly priced. i have not tried the asus, or any asus, since socket 754 so i cannot give an honest opinion.
good luck.
The Asrock 939Dual can run SATA2 and has most of the features the OP listed and is only $68 at Newegg.com
I have this mobo but be wary, there is a large capacitor sitting right next to the 20 pin PS.
