What work? (VR is not actually moving you around so no 20%-30% there)
I am actually accurate.
What work? All the output that happens. Graphics on your screen, the millions of calculations per second it takes for everything you do on a computer... All that is work, it takes energy. It's not all converted into heat. I don't think you're accurate at all. If all the energy is converted to heat, computers wouldn't be able to do what they do because there would be no energy left for actual work and desired output. If you think you are accurate, please tell me how is it that I'm able to make this post and how did you manage to read it? Where did that energy come from if everything that was used from your outlet was converted into heat?
My example of motion was related to vehicles doing work. Computers do work also, just a different type, and neither cars nor computers convert all the energy used into heat.
In fact, if what you're saying is accurate. Power supplies would actually be heaters. If all the energy they used were converted into heat, the box would just get red hot and not be able to output any usable power.
