So I started running SMP on my 1075t using all 6 cores, according to the client (beta 7 I believe) in windows it is only producing 1500ppd? Is there a set number of WUs you need to complete before getting the bonuses like on GPU WUs? I feel like this CPU should get me at least 10K PPD, but that is far from true since it says it will take 5 hours per WU and the base credit is only 500ppd. Can I use HFM.net yet with the new client and see if I can get a better answer for production?
