NoOther
- May 14, 2008
nothing but the generic pictures/descriptions
question still remains unanswered....wtf does he actually do other than throw LN2 on it, turn up voltage, and increase clock offset....all of which we can do on any other card
again - CPU I can respect - so many more variables to play with...but GPU I just don't understand. I want to be proven wrong by ignorance, but nobody who actually knows anything is speaking up - just fans drinking the kool aid of the name brands
Have you even tried reading any of the OC forums? There is tons of information on OCing GPU cards out there. And I am not sure what you want as a difference in OCing EVGA vs OCing other cards? They use the same GPU, and you use the same methods to OC them. The only difference between different resellers is the components they use and the PCB makeup. And even the PCB isn't necessarily that different since they are all based off the reference PCB that Nvidia puts out.
The main differences you will get with EVGA vs ASUS vs Whoever is the components they use and the coolers they use. Some of which you can replace yourself if you know what you are doing.
As for what Kingpin actually does, do you think he would list everything? He has once or twice in the past explained some of the things he does to get his crazy overclocks, but he never reveals all of his secrets, i mean when your job is to compete for the top OCs, why would you reveal all your tricks? Some of the things he has done is replace certain components on the cards, reduce resistance in certain areas to allow for higher voltage to parts on the board, flash the firmware with his own custom setups, etc.
As with all overclocking, one of the keys is to be methodical and gradual. Boosting the voltage up too quickly can adversely affect the card and limit your peak. You are far more likely to get a higher ceiling if you move slowly and methodically rather than just jump to the first 'safe' OC settings.
