A fool and his money are soon parted.
-Thomas Tusser
Big surprise, its a digital signal, cables matter not.
I doubt it. This reminds me of the first computer I ever bought, which unfortunately was at a BB in 1998. Hey, I didn't know any better.I take it BB and other retailers don't want people to see that review..
But the general public didn't This is good information they need to know.
Corrected LOL.A fool and his money are soon parted.
-Steve Jobs
I do home theaters for a living, and I've been saying this since HDMI came out. It's digital data, just like optical cables. The signal is either there or it's not.
Now if I'm doing a run over 15', I start looking at more expensive stuff, but under that, monoprice cables work perfectly for me and my clients. I actually use it as part of my pitch, when all my competitors are using these crazy expensive cables and trying to justify it, I tell them that every cable going into their system is $30 each. Make the client feel all warm and fuzzy like I'm not trying to rip them off...
I did a comparison years ago, used a $10, $100, and $500 cable. NO DIFFERENCE at all. If anything, the expensive one looked worst, but that may have been a bias on our part!! LOL
And that warrants a $100.00 or more markup in price? Hell no!!!
You also make the mistake of assuming everything in China has poor build quality which is not true. Even Cambridge Audio equipment is built in China and it is not junk build quality.
I was unaware that the thousands of factories and millions of people employed in said factories in China all manufactured things in the exact same way.
"Made in China"=Crap may have been true thirty years ago. It has absolutely no bearing on quality today - what matters is the standards to which the product was manufactured, not the location it was manufactured.
You can buy 30 $3 HDMI cables for the price of one Monster HDMI cable. I doubt you'll go through $30 cheap HDMI cables even if you are hotswapping your stuff 15 times a day. I have a 50' HDMI cable from Bluejeanscable that I payed about $50 for (cheap for an HDMI of that length at the time I bought it, ~5 years ago), and it works great. Never any trouble.
Corrected LOL.![]()
Ive noticed walmarts around me have started selling cheaper $10 6ft hdmi cables and they can never stay on the shelf lol. Made me mad to cause I needed one more hdmi cable for my new PVR and they were sold out for 2 weeks straight, while I can buy one cheaper online it only stays cheaper if im ordering other stuff. Otherwise shipping makes it the same price and I have to wait for shipping. For now Ive started buying my hdmi's at walmart again![]()
No, definately not. Just like there are whites who can jump, there are items built in China which have good build quality. The general rule of thumb still applies. This is why most of the major Japanese AVR builders (for example) make their low end models in China but their high end models in Japan.
I noticed you like to pretend things were said and then argue against them. You should stop doing this, it makes you appear foolish. Most people do not want to appear foolish, so I thought I would let you know.
ECC can only compensate so much. This ain't NASA ya knowHDMI will display normal looking frames even with a lot of missing and incorrect 1s and 0s. A lot of people that have tried long runs of HDMI cables have seen this, you end up with "sparkly" image frames and the show goes on. Whoa, but its digital, it should be perfect or not work at all, how does that happen?![]()
Low quality stuff is always crap. Low quality HDMI cables are crap. They'll fall apart, they don't protect against electrical interference, they'll give of toxic fumes, they won't work over longer distances, whatever. The good news, quality HDMI cables are still dirt cheap.
Without shielding, in an electrically noising environment, a lot of zeros and ones will get lost in a digital cable. There's no error correction to fix this, so a crappy cable will produce a lower quality picture. If there were error correction, as there is with Youtube over Ethernet, a crappy cable would result in a loss of speed, rather than picture quality.
Good to know. Next time I want to hot-swap HDTV's underneath a functioning high-tension power line in next to a toxic waste plant that was hit by a nuclear weapon (taking time out to huff the new electronics smell coming off of the cords) I'll take your advice. It certainly would have been good to know the last time that happened.
Good to know. Next time I want to hot-swap HDTV's underneath a functioning high-tension power line...
That being said, the HDMI standard is all you really need, the rest (like gold plated contacts) is overkill.
they are differences, my monoprice cables have started falling apart at the connectors, while my more expensive cables are fine![]()
Or you could buy a dozen monoprice ones for the price of the expensive one and just replace them as they fail. I am sure they will still last a LOT longer.
@nakedhand: actually in case of streaming devices with no time for error correction the interference does matter. Of course again we talk about crazy cable lengths, not your ordinary 1m USB cable. On other side, i can't imagine anyone choosing USB over SPDIF/Toslink for anything more than 1m.
Isochronous Transfer
Isochronous Transfer is most commonly used for time-dependent information, such as multimedia streams and telephony.
This transfer type can be used by full-speed and high-speed devices, but not by low-speed devices.
Isochronous transfer is periodic and continuous.
The isochronous pipe is unidirectional, i.e., a certain endpoint can either transmit or receive information. Bi-directional isochronous communication requires two isochronous pipes, one in each direction.
USB guarantees the isochronous transfer access to the USB bandwidth (i.e., it reserves the required amount of bytes of the USB frame) with bounded latency, and guarantees the data transfer rate through the pipe, unless there is less data transmitted.
Since timeliness is more important than correctness in this type of transfer, no retries are made in case of error in the data transfer. However, the data receiver can determine that an error occurred on the bus.
Even the cheaper $29 cable at Best Buy has a lifetime warranty. You can waltz into the store with your cable that's falling apart and waltz out with a new one. This is one thing I never got while I worked at Best Buy. I worked there for almost six years, and for the last year I worked at geek squad. It was only part-time, as I had full-time employment elsewhere, but I still enjoyed it, and liked to help folks out.
+1.
Only thing I have from monoprice that I didn't like is their basic RCA to 3.5mm y cables.
Hey Mr. Gullible, I've got a cable for you.Low quality stuff is always crap. Low quality HDMI cables are crap. They'll fall apart, they don't protect against electrical interference, they'll give of toxic fumes, they won't work over longer distances, whatever. The good news, quality HDMI cables are still dirt cheap.
