Why does PC Probe only show CPU fan speed ???
vilhiem
Hi guys, look at the attached screenshot of my PC Probe application.
It seems to only show my fan speed for my CPU.
Does that mean that it is the ONLY fan working ???
If I click "enable" on any of the other checboxes ... I get a warning message due to the level being zero. But again, not sure if it's just because certain wires for "monitoring" the speed are connected.
Thanks Kindly,
Vilhiem
are the other fans 3pin fans? are they connected to the mobo? Do you have other fans?
not sure if they're "3 pin fans" and not sure how to tell if they're connected to the motherboard.
also, is the CPU fan speed too high ...?
Only certain fans can report to the system what their rpm is.... these are usually 3-4 pin/wire fans, but they do make 2 pin/wire fans and they just blow air. They do not give RPM data.
The fan speed doesn't seem to high to me.
