Why aren't we seeing triple-slot GPUs?
Discussion in 'Video Cards' started by Quartz-1, Oct 15, 2017.
  1. Quartz-1
    Quartz-1 [H]ardness Supreme
    4,331
    May 20, 2011
    With SLI and XF on the way out, surely there's no reason for GPUs to not occupy more slots than they do. The dual-slot design must impose significant cooling limitations, simply from the size of the heatsink. A bigger heatsink would allow for quieter coolers, for a start.
    So, why not?
  2. tacohunter52
    tacohunter52 Gawd
    614
    Jul 9, 2011
    I've seen some triple slot GPUs. I actually used to own an r9 295 x2 that had a triple slot cooler. Sold it to someone on these forums.
  3. WhoBeDaPlaya
    WhoBeDaPlaya 2[H]4U
    2,587
    Dec 16, 2002
    There have been a few 3 slot GPUs in the past, eg. ASUS MARS series :
    [​IMG]
    sabrewolf732 likes this.
  4. 777
    777 [H]Lite
    107
    Nov 8, 2015
    R.I.P. vertically mounted motherboards.
  5. Araxie
    Araxie [H]ardness Supreme
    6,046
    Feb 11, 2013
    in fact vertically mounted motherboards does suffer *less* than typically mounted ones, they have less tension on the PCI-E slot and less bending on said slot, because it's the case who offer the support to the cards and not the slot itself.
    90° rotated mobos doesn't suffer from this:
    [​IMG]
    [​IMG]
    Armenius likes this.
  6. Quartz-1
    4,331
    May 20, 2011
    So, primarily a weight issue?
  7. Frito11
    Frito11 Limp Gawd
    280
    Dec 13, 2016
    My single slot 1080 Ti takes offense to this discussion..
    to be honest though the real answer to your question is 95% of motherboards are laid out for dual width cards for multi-gpu configs..
    Ocellaris likes this.
  8. JRUHg
    JRUHg Limp Gawd
    370
    Jan 5, 2016
    asus gtx 1080 ti AURA
    takes 2.5
  9. tofumonster
    tofumonster n00bie
    2
    Jun 2, 2013
    I would think we don't see triple-slot cards because the cards we have today are so small now
  10. DanNeely
    DanNeely 2[H]4U
    3,357
    Aug 26, 2005
    As you noted they do exist. The reason they never caught on is that they don't offer enough additional performance relative to their higher cost to be justifiable. The premium was too high for most air cooled gamers, while the money is no object crowd just slapped a water block on the card and called it a day.
    Xinmosni, Joseph F, Armenius and 5 others like this.
  11. kasakka
    kasakka Gawd
    829
    Aug 25, 2008
    It's a better idea to have an AIO water cooler by the time you don't get enough cooling performance with a dual slot setup. I just wish more of those were offered on the market when a new card gets released.
  12. Quartz-1
    4,331
    May 20, 2011
    Why? An AIO uses up a fan slot and you better hope that the tubing is long enough.
  13. spine
    spine 2[H]4U
    2,302
    Feb 4, 2003
    Exactly, the extra space can't be used economically. If you used a massive and expensive 3 slot copper heatsink, the performance would still be worse than a cheaper water solution.
  14. hitched
    hitched Limp Gawd
    179
    Jan 12, 2011
    My aorus 1080 ti was a 3 slot card... but i bought a water block for it when I got the card so can't really say how well the cooler worked
  15. RamonGTP
    RamonGTP [H]ardness Supreme
    7,360
    Nov 9, 2005
    There's no reason for it. Unless NVidia/AMD through power to the wind and just build the most powerful GPU they can adequately cool it's simply not necessary to use that much space and that much material to cool a GPU with the exception being if you want to go fanless. 2 and 2.5 slot cards are easily dissipating the heat form 250-300 watt cards
  16. kasakka
    kasakka Gawd
    829
    Aug 25, 2008
    If you need more cooling performance than a dual slot cooler then AIO will be more effective and makes less noise.
  17. ryan_975
    ryan_975 [H]ardForum Junkie
    14,397
    Feb 6, 2006
    That's at least a 6 slot 1080 TI as it's configured. :p
    Frito11 likes this.
  18. realworld
    realworld Limp Gawd
    282
    Apr 24, 2016
    I think chassis airflow for graphic cards is more concerning than a dual-slot cooler. You can use a 5 slot cooler and the issue still remains the same: how do you expel those hot air out efficiently without negatively affecting your entire system temps.
  19. DanNeely
    DanNeely 2[H]4U
    3,357
    Aug 26, 2005
    In some mITX gaming cases they solve the issue of limited volume to hold the heat on its way to the 140mm big and slow fans on the top/back of the case by having the card's cooler placed directly against a GPU sized air vent so it can expel hot air out of the case using its biggest side not the smallest one.
    Even without that a single 120/140 mm fan moves enough air to theoretically empty/refill the case every second or so. As long as you've got decent internal airflow you should be reasonably OK.
  20. defaultluser
    defaultluser I B Dum
    11,564
    Jan 14, 2006
    It's overkill, and way harder to fit in a case.
    Dual-slot coolers were utilized once cards got over the 110w threshold, as blower cards were getting incredibly long just to keep them cool.
    Dual-slot blowers can handle cards up to 250w at the same length. And the extra depth also makes it possible to use axial fans to reduce noise levels.
    This single-fan heat-pipe axial cooler is capable of handling a 120w GPU.
    https://www.newegg.com/Product/Product.aspx?Item=N82E16814487261
    The dual-fan version could easily handle 250w fairly quietly, and triple fan is overkill for most cards that are not overvolted.
    Adding a third slot of depth adds extra cooling capacity, but it's not the massive improvement we saw going from 1 slots to two.
    If power consumption doubled to 500w, there might be a case for going triple.
  21. tangoseal
    tangoseal [H]ardness Supreme
    5,922
    Dec 18, 2010
    What the F do you want a triple thick card for? you lose so many other slots doing that retarded design. I only wish GPUs were going to start coming out single thin.
  22. _mockingbird
    _mockingbird Gawd
    608
    Feb 20, 2017
    Zotac Geforce GTX 1080 Ti AMP Extreme Edition
    [​IMG]
    [​IMG]
  23. MrSteel74
    MrSteel74 [H]ard|Gawd
    1,566
    Nov 17, 2000
    I had the 1080 version and that car was a BEAST, I propped it up with a paper straw to help take the stress off of my PCI-E slot.
  24. RazorWind
    RazorWind 2[H]4U
    2,987
    Feb 11, 2001
    What the F do you need all those extra slots for?
    There are at least a few triple slot cards on the market now; the higher end Zotac cards being what comes to mind first.
    It strikes me as likely that compatibility with smaller cases is the reason this isn't more common. Weight could conceivably also be an issue. The non-reference design cards I've handled in the last couple of years have all had a tendency to sag, and I could see this being even worse if you put a bigger, heavier heatsink on them.
  25. MrDeaf
    MrDeaf Limp Gawd
    275
    Jun 9, 2017
    For gaming PCs, People plug in cards, other than GPUs these days?
    I could see wanting the more traditional 2 slot for an mATX+mGPU or mITX setup.
    However, for ATX mobos, most of them only support 16 PCI-e lanes between 2 slots anyways, so they can't even do a proper 3x or 4x SLI setup.
  26. Hakaba
    Hakaba I Think I am Funny, but I'm Not
    318
    Jul 22, 2013
    So you guys forgot about the quad slot GTX 1080? I would rather have separate systems than a massive all I one.
    [​IMG]
    [​IMG]
    Dayaks, N4CR and Red Falcon like this.
  27. horrorshow
    horrorshow 2[H]4U
    3,961
    Dec 14, 2007
    [​IMG]
    Red Falcon and N4CR like this.
  28. StormClaw
    StormClaw Gawd
    541
    Jun 10, 2009
    Says who?
  29. tangoseal
    5,922
    Dec 18, 2010
    Yeah because everyone is 100% pure gaming. I am 99% but 100% of the rest of the 1% I use my PC for work and other tasks oh and my 10g fiber optic card to my NAS, etc....
    So yeah we do.
  30. DanNeely
    DanNeely 2[H]4U
    3,357
    Aug 26, 2005
    Says the steady decline in titles that can take advantage of it. Says the removal of 3+ card SLI for newer generations of cards. Says DX12 making multi-card support a job for the game developer not the driver developer optimization specialists. Says the increasing use of temporal processing effects which combine data from the current frame and the previous one that make multi-card implementation much harder because it greatly increases the amount of data that needs shared between cards to do alternate frame rendering.
  31. defaultluser
    11,564
    Jan 14, 2006
    But there's no real-world benefit over existing dual-slot triple-fan cooler. It's just Penis Enlargement for the sake of Penis Enlargement.
    So the card is large and harder to install, it costs more, and needs to be properly supported.
    Do you not see why there's a pittance of a market for these behemoths? And that's exactly what we have available - you can buy a SELECT FEW triple-slot GPUs. That will not change anytime soon.
    We went dual-slot because we HIT THE LIMITS OF COOLING PHYSICS at 150w and above.
    But we're not going above 300w for anything but specialty cards anytime soon, so dual-slot is plenty.
  32. Emission
    Emission 2[H]4U
    4,069
    Dec 6, 2005
    The logistics don't add up. The bulk of the sales are in mid-range GPUs, and I imagine the bump in cost for manufacturing and shipping 3-slot coolers isn't worth it given the cost/benefit equation.
  33. AngryLobster
    AngryLobster Clueless
    113
    Aug 24, 2016
    I dunno about 3 slot GPUs cooling worse than AIO's. I have both a 1080 Ti Lightning and a FTW3 Hybrid. The Lightning matches the Hybrid and is actually quieter (high 50C).
    Keep in mind it's actually 2.5 slots, if full 3 slot behemoths existed I have zero doubt they'd out perform an AIO in terms of noise/temp and I have no problem with partners shipping their cards with GPU support brackets like MSI is doing now with the newly released triple fan model 1080 Ti.
    I find pump noise annoying as is a radiator with hoses so I wish more cards were 3 slots in a time where space under and ATX board is completely wasted.
  34. MrDeaf
    MrDeaf Limp Gawd
    275
    Jun 9, 2017
    But do all those cards use up all your slots?
  35. tangoseal
    5,922
    Dec 18, 2010
    Nah I havw two poseidon gpus so theyre 2.5 slots giving me one extra I use for 10g. 3 wide wouldnt allow any thing.
  36. _mockingbird
    _mockingbird Gawd
    608
    Feb 20, 2017
    COLORFUL iGame GTX 1080 Ti KUDAN
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Comixbooks and Archaea like this.
  37. Meeho
    Meeho 2[H]4U
    3,444
    Aug 16, 2010
    It seems most people here don't care about noise. Triple slot cards enable bigger heatsinks and/or bigger fans. I have my GPUs modded with standard 120 mm fans and they are silent under load the same as idle. No, I don't want crappy and noist AIOs and I have no interest in proper WC, which would still be at least as loud, if not louder, than my current setup.
