Why are new Android phones still being announced and released without ICS?
Discussion in 'Smart Phones and Devices' started by MrCrispy, Jan 30, 2012.
  1. jadesaber2
    jadesaber2 Limp Gawd
    289
    Nov 8, 2005
    ftfy. Menu button is going away.
  2. kllrnohj
    kllrnohj [H]ardness Supreme
    6,846
    Apr 1, 2003
    The iPhone 4S doesn't have pentaband. The GN is a better world phone than the 4S if you care about data speeds. Also GN is HSPA+ whereas the 4S is HSPA. Putting both CDMA and GSM into the same phone is a neat trick, but it is mainly for Apple's SKU purposes than something that is actually useful to consumers.
  3. kllrnohj
    6,846
    Apr 1, 2003
    The 3 buttons are back, home, and multitask. The search and menu buttons were both "removed", or at least that is the direction Google is pushing things.
  4. notetcetera
    notetcetera [H]Lite
    124
    Jun 16, 2011
    Except that they cause more problems than the conveniences they give.
  5. vsboxerboy
    vsboxerboy 2[H]4U
    3,662
    Oct 17, 2005
    Yeah but I think those are not going to be hardware buttons anymore - just on screen. Anyway, it's kind of a moot point because there are hacks to bring back the menu and search button if you really want them
  6. tangoseal
    tangoseal [H]ardness Supreme
    7,156
    Dec 18, 2010
    Im using Gingerbread on my Thunderbolt but I would love to try ICS. Is there an ICS ROM available and if so where would I be able to find it?
  7. Ryokurin
    Ryokurin [H]ardForum Junkie
    10,560
    Aug 14, 2001
    4S is hspa+ 64QAM is not a requirement for release 7, despite what wikipedia implies. Also, for what it's worth, the only time you would run into problems with not having 1700mhz is using Tmobile. Everywhere else in the world 2100mhz is used to send and receive, unlike just to transmit on TMO.
  8. Vermillion
    Vermillion 2[H]4U
    4,073
    Apr 5, 2007
    You can find ICS ROM's on rootzwiki.com and the xda-developers.com. be warned the RIL for TBolt is not yet finished so you won't have data or calls. One dev group (Liquid Smooth ROM's) has apparently got RIL working and are just working out the last of the bugs so hopefully we have a truly working TBolt ICS ROM soon.
  9. ians2k
    ians2k n00b
    52
    Jan 17, 2005
    is it only ICS making use of the dual core?
  10. CHANG3D
    CHANG3D [H]ardness Supreme
    4,728
    Jul 23, 2010
    I supposed most of that is true, but I'm a Sprint lifer, baby!
    Screw big sopa-supporting, anti-net-neutrality coorporations!
    If you have that kind of political conviction, don't support those companies.
    I also buy groceries from farms without Monsanto.
    Yeah, I'm one of THOSE people!
  11. Zurginator
    Zurginator Gawd
    853
    Nov 16, 2009
    Because it takes ~2 years to push a phone through the carrier's systems.
    Add a delay for ICS, and the useful life of the phone is cut down.
  12. yimingwuzere
    yimingwuzere Gawd
    618
    Sep 13, 2009
    Add another culprit to the equation: Qualcomm.
    Why does the Nexus One / Evo 4G / Desire not have ICS? Simple, they're the culprits. There's no open source Android driver for the crappy Adreno 200 GPU, and it appears they're not going to update their closed binaries for ICS either.
