username00
- Nov 5, 2012
lmao... the customer reviews are 4.8/5 stars!
Everyone of these reviews is pure gold
The worst part is many of the employees at retailers are adamant there is an actual difference in image quality due to cable construction when working with digital signals.
I go to monoprice for my cables. I get the shortest run I need with the thicket gauge they sell. That's what really won me over, was being able to get thicker gauges in shorter runs. If I had to pay more for the thicker gauge, so be it. I like the peace of mind knowing that the cable I picked out won't have any trouble sending the signal.
The only thing I can't seem to find a straight answer on, is whether or not ferrite cores are necessary.
It still matters with digial, it just doesn't matter as often or as obviously. I have plenty of really cheap USB cables that often don't work at all with certain high speed devices because their shielding and/or crosstalk is so bad the signal doesn't survive. When they do work data transfer rates for HDs are abysmally slow compared to using a higher quality cable. They work fine with slower devices.
I thought i read a review somewhere that determined the cost of hdmi cables do play a role in quality.... but only at large lengths.
I only buy the cheap stuff, but i do see difference between some, not in quality but sometimes the picture freezes on some , or some kind of artifacts are shown on screen, or the screen turns pink .
i believe some have really poor cabling , very small gauge wires that lose signal etc.
still i rather buy 10 1$ cables and throw out 1-2 to the trash than buy one 'quality' cable for 10$
I'm convinced there is price fixing in regard to accessories in retail.
Also, I don't think printer manufacturers decided to stop putting cables in the box on their own. I know how shady this shut is firsthand.
The not supplying a printer cable in the box goes back to before USB was invented. They never included the parallel cables either. That way they can sell you those "special gold plated" cables.Retail stores basically told printer vendors that if you include a USB cable with your printer we won't sell it. Period. Retailers make more profit off of the "high priced" USB cable than the printer itself. And the ink jet ink. That's a goldmine for retailers. That is why printers come with a "starter" ink set. Get you hooked, then you come back for more ink.
Well, considering EVERY SINGLE FUCKING CABLE I've bought from monoprice has failed within a few months, there's a good reason why they're so cheap. These were ipod and HDMI cables. The damn HDMI cable was plugged in once and forgotten about till a month later when it decided not to carry a signal. You don't need to spend thousands on a digital cable, but if you buy the cheapest thing you can find, you'll get what you pay for. I'd rather spend $20 on one cable that actually works until it's depreciated than buy 20 cables for $1 each that have to be replaced every other month.
A big lol @ monstercables being expensive. They may not be worth half of what they cost, but they're still very cheap in comparison to other brands.
I used to do hardware QA for a firewall appliance. We tested various USB CD/DVD drives with varying lengths of cables. Anything over 7 ft on USB was pushing it. A 10 ft on one drive had no errors while the same 10 ft on another drive would have errors. The power requirements of the drive played a big part, never the actual cable quality - I would guess the same holds true for HDMI.
Since HDMI is Digital, they either work or they don't work.
As long as the signal isn't degraded below a point where you start losing bits
As long as the signal isn't degraded below a point where you start losing bits, then the cable will work just as good as the most expensive/perfect cable available.
All cables are going to have non-zero bit error rates; digital does not mean error-free. On HDMI, these errors may actually show up on the display because it is (mostly) a unidirectional link with no error correction.
Short cables (10 feet or less) should never be a problem, as long as they aren't so cheap the connector falls apart.
I'd stick with high quality cables for anything longer than 25 feet, as cheap cables are more likely to degrade the signal or pick up interference.
Might not pay for "quality", but may want to spend a few dimes on avoiding defects.
HDMI data is isochronous and has to arrive at the destination at the same time interval and be 100% correct.
amazon basic cables... their entire line of cables has worked fine so far
because at the stores it is an item that the consumer needs yesterday so they will pay 20 bucks for a 2 dollar item
Some of these have got to be faked. Hilarious none the less!
Just got my first Amazon Basic cable. I was on vacation and wanted to hook up my laptop to the TV, but forgot my HDMI cable at home. I wanted to watch a show that evening, so I looked up the only store in town (Radioshack of course) and went to take a look. The guy who came up to ask me if i needed help just kinda hovered over my shoulder after showing me to the cables... kinda creepy and annoying. But anyway, after i saw it was 20 bucks for a 6' cable I left. No way was I going to pay for that. Even if i needed it now. Having amazon prime, I looked up HDMI cables, thinking i could get it shipped next day.
To my surprise, i could! 5 bucks for the 6.5' cable, and another 4 for shipping next day. 10 bucks after tax, half the price of the Radioshack cable. I can wait a day and save 10 bucks.
Radioshack can suck it.
Analog cables are one thing, where the shielding and materials DO matter. Digital cables like USB, HDMI, optical, etc? No, it doesn't matter. Not the gold-plating or the shielding or whatever.
The problem will be noise from the mains wiring. The more expensive cable will have better shielding. Or you could just separate the mains and HDMI cables apart further.I had terrible luck with long runs of Monoprice HDMI cables going to a ceiling mounted projector, had sparkles all over the screen with two different cable. The cable run was going along side some power wiring and numerous pipes, no idea what the problem was. Had to purchase a more expensive cable and it fixed the problem immediately.
