CommanderFrank
Cat Can't Scratch It
- May 9, 2000
If you’ve ever shopped around for HDMI cables as most of us have, you are probably still baffled by the wide range of prices you will find for what looks like the exact same cable. So what’s the difference? Inquiring minds want to know.
All material used in HDMI cables are pretty standard and the “standard” HDMI cable will provide everything you need if you are an average consumer. There is no good or bad here, there is just good or slightly better than Good.
