They are not legal for use in europe because they can be plugged into a wall outlet!! WBT makes a european legal type and it has an extra plastic pin to keep some chucklehead from plugging it into mains voltage.
Yes we in the UK were not too happy about this as we have a totally different (and I may add far superior) power socket and plug setup with square pins and also the socket has a covering mechanism that only opens up access to the live and neutral points once the longer earth pin has gone in. This saves a baby sticking a knitting needle in the live socket etc. Oh and it has a proper fuse as well. Apparently the eurozone is always hinting at making us switch to their lower standard but if you visit say France or Spain all you see is euro sockets hanging off walls with wires on show. Elcectrical safety isnt that good in mainland europe. Have to say the number of electrical sockets I see in bathrooms in the US concerns me too!!
As for hifi gear, a lot of manufacturers have found a way around it anyway. They fit the new style sockets but if you unscrew them, what do you find? Oh that looks just like...a banana socket!
I'd have to agree with the other dude that UK sockets are far superior, not just because I am from the UK, but having seen US/Europes and the UK's setup I would have to agree that the Uk's setup is the most secure in terms of safety...
US is still more safe though as it is 115v....it does not kill you if you get shocked liked in other countries with higher voltages like the UK. Its not fun, but I have been shocked before and it is just a wake me up in the US. Now you can also argue that the 220 has the advantage of being more efficient (it loses less power over a length of wire compared to 115v), but it is also much more dangerous.
It is scary to be an electrician or work with electricity in the UK and Europe as one wrong move and you could die...115 is much safer from that regard. That is also why the outlets are more secure in the UK, one wrong move and you are dead there!
Higher voltage is not a major factor determining the intensity of the shock. Where you put your foots and the ambient humidity is much more of a threat. People are so misinformed about those things ...
Also, the current as well. I got shocked with 1,000s of volts today, too bad it was just static electricity.
Yes, and given the same foot position and ambient humidity levels, an electrical shock from a 220V source is much worse than from a 110V source because the 220V can allow more current to go through your body.
But, what amperage is the 220v source?
Another case in point, under a typical conditions, I doubt we can really squeeze a 1.5V battery or 9V battery hard enough against our skin to feel a shock (I suppose if you had masochistic tendencies, then I guess you could push them hard enough that you started bleeding and created a lower resistance contact point). However, a Taser uses those same batteries, and converts the voltage to a couple of thousand volts to create that nice electrocution feel. Hence, voltage does matter and the higher the voltage, the nastier the shock.
No, dc is horrible for long distances. It was first used in the Us but got replaced by ac since dc current doesn't travel very far at all.Isn't the American 120v AC and the European 220v DC? I would think that also would make the 220v worse.
yes, I used to do it for funEver hold a 9v against your tongue
I misread the subtitle and thought it said "Why are banana SLUGS prohibited in europe?" the answer to that question would probably be it throws off the balance of the ecosystem.![]()
Don't know where you live but its 120v (121 with a multimeter) where I live. (Utah)Where does all this talk of 220v come from, I thought we were speaking about UK and US mains volatge, which in the UK its 240v but in reality its 250v and in the states its 115/110
F@@K the mainland Euro's, they dont count![]()
before the Eurocrats start getting boners, I is only joking.
Well America is a hodge podge of nationalitiesMy user name should give you a big clue asto where I live
No, I wouldn't believe so. The ideal power supply is one that delivers perfectly 'clean' and stable power, not one that necessarily delivers a lot of voltage. Then again, I know about as much about electricity in general as I do women's underwear (the bra goes around the waist, right?)You guys think having higher voltage in the UK gives audio better sound quality than what we get in NA?
Oh and btw... your multimeter plugs can ONLY be used for measurement purposes.
Don't try to run high currents trough it! they might ' seem' safe because of the plastic tube but they're in the best case made from silicone-rubber or lower quality isolation. Heat it up and it'll melt.
