- Jan 24, 2002
I just built this pc tonight beacuse I never got around to it and had parts laying around for over a year..
Build: Intel p4, 3.4ghz HT
Intel mobo: D915PBL
I am running a SL128 with a 120mm fan that pushes out around 70cfm...
My current processor temp is 47'c IDLE
I am using artic silver 5.
I tried both methods of appling the grease.. size of BB in center and push heatsink on... then when I saw the temp stated above I figured that was bad, so I then took it off and put a THIN coat over the entire heatsize of the processor...
Any advice?
I don't know why it's running to hot.. this seems WAY too high... my p4, 2.8ghz is only running at 34'c at idle...
This is one of the reason's why I bought the SL128 because it's supposed to be awesome...
I am positive that all 4 contact points are making contact on the motherboard but it was a pain in the ass, you clip one corner and then the other corner would lift up..etc I thought I was going to break the mother board trying to get all 4 fasterns to click..
It's in a Lian Li pc65b plus.
So it has a 120mm intake, 80 blow hole, and 80mm exhaust along with a side blower...
My old p4 is also in a lian li pc 65, But that has two front 80mm intakes, two 80mm exhaustand a 92mm blowhole that I made...
Thanks,
-Nigel
Intel mobo: D915PBL
Any advice?
Thanks,
-Nigel
