WHS, , WOOT WOOT!
CarlsonCustoms
So I just got my WHS all up and running using Microsofts 120day free trial. I want to get my feet wet before I jump in or else I'll run back to win2k8.
I'm running it on a Supermicro PDMSE server mobo with a 3.2ghz P4 and 2gb ram. I'm using 4 seagate 1tb drives with the onboard sata ports. Then I added a 3ware 9550sx PCIX raid card and set it up for jbod use. I added 4 500gig samsung spinpoint drives into a 5 into 3 hotswap bay adapter.
So far I have 5.588 TB of useable storage with 4.742 TB free after backing up one pc and holding all my other data. I know I don't need nearly as much space as I have but what the heck right?
I just wanted to say so far it's been a smooth ride.
So if anyone is wondering if they should make the jump, might as well, the waters warm!
I do have one quick question. My board has two intel pro1000 gigabit nics. I have them both connected and WHS shows them connected. Does it do any sort of link aggregation, load balancing etc?
Thanks
I think you're referring to network adapter teaming. I could be wrong, but ordinarily Adapter Teaming is done for fault tolerance more than anything else.
Are you doing this in hopes that having 2 x gigabit nics will increase throughput and decrease latency? I'd say ask a pointed question about it in the Networking & Security forum.
Edit:
I did just find this article elsewhere that may suit your needs just fine. WHS is based on Windows Server 2K3 so the instructions should be applicable. YMMV, of course.
I love this forum. Your link was EXACTLY what I was looking for! So I installed the software and setup my team perfectly. I actually want to do link aggregation but I need to buy a switch that is link aggregation supported. The dlink I have now doesn't do that. So for the time being I have it setup as link fault tolerance.
Thanks again DevilDoc
Edit:
good info. that should go in the faq
