Trepidati0n
- Oct 26, 2004
I wanted to upgrade my wifes laptop HDD. I could have done it with Acronis...but decide to let WHS do it instead to simulate a drive failure. It could not have been simplier.
1. Backup HDD one last time via a manual backup.
2. Shut down and remove battery/power.
3. Remove old HDD (keep just in case) and install new HDD
4. Put battery back in and power cable
5. Connect laptop to network via ethernet cable (no wireless)
6. Put in "restore" CD
7. Follow instructions
8. It will eventually bark that the new drive is empty, just format with a partition (it gives you a button for the sever 2003 type tools).
9. Wait for a while (does about 15 Mbyte/sec from the server to the laptop HDD)
10. Profit???
Honestly...less painful than Acronis (and Acronis is easy) Remember since it is a cluster type bacup...even all the work on Vista in terms of fetching/searching is maintained.
10. Profit???
