Seems my OS drive in my home server is thinking about failing, several times that drive has been marked as degraded in the past couple months. Home server smart says nothing wrong though.
I was going to swap it with a 1TB Samsung that I have here but then I realized that the motherboard has a ICH9R, so now I am thinking I should just go ahead and do a RAID 1 for the OS drive and never have the problem again.
When I switch the motherboard to RAID how should I mark the non OS disks so WHS still picks them up?
Really hoping I can do a reinstall and have it pick up the drive pool. I have been backing up the server for a couple days now and have nearly everything off of it. Only stuff left is non duplicated items for movies I have here that I can easily rerip, just be a waste of time. Does a reinstall really wipe out the non duplicated folders when it rebuilds the pool?
Newegg has some Samsung F4 320GB drives I was thinking about using for boot, thoughts? Those are single platter jobs right? Either that or two 1TB F3. Existing drive is something 5400rpm Samsung but would like to get two more or less matched drives for RAID.
Was previously using a WHS nlite image with the AHCI drivers on it, will redo the image so I get AHCI and RAID drivers on it.
