White fans?
Are there any white led fans with white fan blades out there? Im looking for both 200mm and 120mm...
if you can find any you can always mod the fan add some holes in the shroud for leds. get a leds or led strip and install them yourself:)
@Juggalo23451
It would be the last thing i did do if i cant find any good fans, which CFM is another key factor i need too.
I need the fans to look good, compliment my new case(level10 gt snow) and also push serious air in and out of the case.
Guys any idea where to read up reviews of the mentioned fans? Maybe like a comparison chart or something...
