Which would be considered better
TheOne&OnlyZeke
100% Irish
I currently have a Radeon 9500 NP modded and overclocked at the moment.
i know this card doesn't have DX9 support, not basing this question on that
would a 9800 SE modded be better then my 9500?
What is the 9800SE modded into?
and ya, the 9500 is a DX9 card.
holy crap
i aws sure i read that the 9500 didn't fully support DX9
well then....thats great
still
which card would be better?
Try to softmod your card and the other one if you can and if
the 9500works without problem with softmod and if you can
check the 9800se too if the 9800se works in softmod without
problem get it!!
ohhh and the 9800se better if you dont do softmod...
and your card have dx9!! :p
