Which will help me increase speed more ram, another HD?
vvilliamm
ok im not really sure what else to do to decrease load time for my computer in the future and present. i heard that if you have two hard drives its usually better because you could use one for just your OS and everything you download and save it goes to the other and install every application on your other hard drive making your current hd faster is that true?
or
do i need more ram?
current built
Amd P 2 X2 550 3.8ghz
Gskill 1066 ram ddr2 4gb
WD 1tb hdd sata.
im thinking maybe i need another hdd.
You don't need more RAM. And no, it wouldn't make your current HD faster if you go with a second drive. Maybe prevent further decrease of performance but certainly not increase performance. But a two drive setup definitely doesn't hurt.
But to decrease load time, make sure that you don't have any unnecessary apps (basically apps that YOU installed) running at startup. Also, you could semi-short-stroke the drive meaning that you create a partition that's 20% to 25% of the drive's total space to keep performance. Use that 20%-25% partition for your OS install. Use the rest of the hard drive space as storage.
Or you can always get a SSD
I would go with a faster OS dedicated drive setup with one drive for OS use and other for everything else including installed programs. If you have some spare cash I would go with a 60GB or 120GB OCZ Vertex SSD for OS use and have your 1TB drive as storage. I currently have a 120GB SSD for my OS, a RAID 0 of 3 SAS 300GB 15K drives, and a RAID 5 of 3 1TB drives for storage. My boot times are fast, program and games load times are quick on the RAID 0 and I have plenty of space on the RAID 5 array for personal data. Also consider disabling unneeded services and startup/running applications to decrease boot up time and load times. What type of OS are you on?
Thanks for all your info and responses =]. My load times and running times while on my pc is alright but i felt like i could make it better and its b.c constantly i move, download, and delete 5-10 gb files and over time it seems to lag so i figured its must be my hard drive. i might take the option of buying an ssd or just another regular hard drive. but maybe ill partition my current one since it is 1tb and i doubt i will use up that much space. im not really sure how does that work really if people have two hard drives. if they install the os on the first hdd, do they also install other applications like games etc on their first hard drive or second? and all their items that they downloaded do they download it directly to their 2nd hdd or their first then move it over thanks. Partitioning sounds cheaper but does it work? cause the hdd will still have to move between disks inside of it am i correct? i could be wrong lol i dont know much about this.
Partitioning a HDD is mainly for organization and management of data on a single drive. If you're constantly moving files within your drive, of course, it will be slow, since the same head thats reading the bits will also be writing them. :p A popular reason for partitioning your drive for an OS/App section and Data section would be to keep your data in tact if you ever need to format/re-image your OS/App partition. Two drives would be useful if you transcode media files a lot (i.e. rip media to one drive, encode to a different format while saving that new format on another drive; e.g. rip a music cd onto your main drive in one format, then ecoding into another format while also saving that new encoding onto another physical drive). Also, another thing to do if you move files alot within a drive is to defragment your hdd. ;)
If all you want to do is boost boot and OS speed, install the OS on a high speed mechanical disk or a smaller SSD. Or if money is no object, buy one of those 4 disk PCIE SSD's that Myspace is switching all their servers to. :D
