D
Deleted member 143938
Guest
Here is a pic of my current airflow set up:
http://img267.imageshack.us/my.php?image=airflowjz9.jpg
The CPU (big block in the middle, left of the RAM) is a Big Typhoon.
Currently it's sucking air in (i.e taking air from case and blowing it towards the CPU/heatsink).
I just read that if my PSU (upper left corner in the pic) is taking air out, then the CPU fan should blow air out, instead of sucking in like it is right now. Is this true?
If it matters, the case cover has two grills with holes in it to allow air to pass.
So what I'm asking, for optimal airflow, should I keep the CPU fan sucking air in, or should I turn it around so it blows air out?
