Which slot for single GTX280?
smw
This is an embarrassing question, it's been years since I've built a system, so my apologies in advance. I also couldn't seem to get search working here on the forums, and searching elsewhere couldn't get me a definitive answer.
Which slot should I put a single Asus GTX280 card in my Gigabyte x48-ds4 motherboard? All things being equal, I would have thought it better to place it in the slot furthest from the cpu (the 2nd slot I believe). I have an Antec 900 case, and I can't seem to make it fit in the (1st? closest to cpu) slot without removing the black plastic piece that directs some of the airflow from the front case fan. The manual for the motherboard was of little help.
Thanks.
You can put it in the 2nd slot if you like. Shouldn't be any problems AFAIK. Try it and see what happens.
But what black plastic piece are you talking about?
Both are pci-e 2.0 16x slots. It should work identicaly in either slot.
