Hey all,
I'm building a pc w/ a conroe 6300 and some so-so intel board i'll upgrade later (i'm using the intel retail edge program)... and I'm on a bit of a budget. I have a couple decisions I need to make.
First problem:
Do I go with 1gb of memory and a 8800gts or 2gb of memory and an x1950pro? I'm kind of leaning towards 1gb of memory and the gts because it's easier to upgrade memory later than the video card. Maybe it'd be worth it to just go a little cheaper on the vid card and wait to see what ati's dx10 stuff is like though?
Second problem:
Somewhat related to problem 1. Is going w/ ddr2 800 instead of 667 worth it? Is there any non-incredibly-expensive 667 stuff that hits 800 fairly easily?
Thanks! Any recommendations on what I should buy would be greatly appreciated.
jason
First problem:
Second problem:
jason
