kangaroo24
- Jan 30, 2006
Which would you recommend:
1 x 150GB WD Raptor 10,000rpm
or
2 x 200GB WD 7,200rpm in RAID 0
or
general said:RAID-0 is only really useful for moving large files. If you do video editing you might need it, but for mainstream use, the Raptor will be better. That being said, will the extra 3 or 4 seconds saved loading your OS from a 150Gb raptor be worth that much more to you than doing so from a 36Gb or 74Gb Raptor?
kangaroo24 said:Which would you recommend:
or
