I'm ready to replace this loud PCP&C 510W with something quieter. Here is what I'm durrently looking at, all of which are made by Seasonic from what I've heard.
My system specs should be something like this:
Antec P180
Intel E6600 @3.2GHz
2GB DDR2
7 x Seagate 320GB
2 x Seagate 160GB
1 x WD Raptor
ATI X1900XT
X-Fi sound card
Broadcom RAID card
DVD RW
PC Power and Cooling Silencer 750W
pros: can get a custom harness (huge advantage), has a single 12V rail, comes sleeved
cons: single 80mm fan for cooling so quietness is questionable, 7.1" long, most expensive, especially with the $50 custom harness
Corsair HX620
pros: 120mm fan for cooling, 3 positive reviews, modular cables, 5 year warranty, made with P180 in mind
cons: no custom harness available, not sure if "forceflex" cables will allow addition of snap on SATA connectors
Antec Trio 650W
pros: 120mm fan for cooling - no reason it wouldn't be quiet, available today, rated at 50 C
cons: no custom harness, no sleeving, no modular cables, only 4 SATA connectors
Seasonic M12
pros: 120mm fan for cooling - no reason it wouldn't be quiet, modular cables, available in 700W
cons: no custom harness, not currently available, limited info
One thing about the M12 and Antec, the cables aren't sleeved at all, which looks ugly, but it allows you to use those snap on SATA connectors to add connections.
Antec P180
Intel E6600 @3.2GHz
2GB DDR2
7 x Seagate 320GB
2 x Seagate 160GB
1 x WD Raptor
ATI X1900XT
X-Fi sound card
Broadcom RAID card
DVD RW
Corsair HX620
Antec Trio 650W
Seasonic M12
