Which PCIE s754 mobo?
bigdavethehorn
OK, I've decided that the best upgrade path for me is to replace my KV8-Pro and 6800nu with a s754 PCIE mobo & a 7800GT.
So, which mobo suits me? And will it OC as well as the Abit does?
i used asus k8n4e and it was a pretty good overclocker. it was picky with ram and also took a few seconds to boot after a reboot (seems all the new asus boards do this). it was cheap and ran well with a x850xt
CCUABIDExORxDIE said:
DFI Infinity s754 pci-e mobo. hands down winner.
Does that DFI support the range of mobile processors like the Lanparty?
Unfortunately, I can't find that particualr motherboard on sale here.
I was looking at the Epox EP-8NPA-SLI, but I don't think that the Vcore will go high enough for the CPU that I'm using at the moment.
Any other ideas?
Any other ideas?
where are you buying from?
i have the dfi and its a good one, but there are a few s754/pci-e out there... biostar has a t-force version out (i would have bought this one myself, but i needed more pci slots)
list from newegg:
http://www.newegg.com/Product/Produ...ice=&MaxPrice=&SubCategory=22&Submit=Property
