Ok so I am trying to decide between these two PSU's for my first build
BFG Tech LS SERIES LS-550 550W
Rosewill RP600V2-S-SL-S 600W
I was going to go with the BFG but ran across the Rosewill which is the same price as the BFG (After the BFG rebate) and I will save some on shipping. Overall it saves me just under $30. So which one should I go with. If the $30 investment is worth it then I will go with the BFG.
Here is the build it will be running
Case - NZXT LEXA BlackLine
Motherboard - GIGABYTE GA-EP45-UD3R LGA 775 Intel P45
CPU - Intel Core 2 Quad Q6600
RAM - G.SKILL 4GB (2 x 2GB) 240-Pin DDR2
Hard Drive - Western Digital Caviar Black WD6401AALS 640GB
Optical Drive - LG Black 6X Blu-ray/HD Model GGC-H20L
Graphics Card - BFG Tech GeForce 8800GTS (G92)
So what do you guys think?
